Mirek6
Flight distance : 609724 ft
Nilesh-spark Posted at 2018-7-3 09:19
For learning purposes... Yes.. So, I was busy getting the shot below, and there was some movement on my screen. I looked up, and it had started drifting. I tried to steer her back to position, but there was no response. Usually, my go-to strategy was to click it into sports mode, and back, and it usually regains control. I tried this, but no luck. It carried on going. As soon as it was out of sight, I hit RTH, but it was too late.
Thank you again.
This is consistent with auto-landing which was started by you hitting RTH when in ATTI.
We cannot confirm such things 100% (DJI is not answering our questions) but we can learn from looking at logs and co-ordinating what we saw with testimony of people like you.
It is hard to test what happens when you hit RTH when Spark is in ATTI because it is hard to deliberately get Spark to ATTI (yes we tried - I discuss it with JJB in private messages - he is doing a lot of experiments like this which helps us to help others better).
Your case shows that this is most likely what Spark's firmware is programmed to do:
- when RTH in P-GPS - Spark returns home (if home point is set)
- when RTH in OPTI, Spark hovers (confirmed by JJB)
- when RTH in ATTI, Spark starts auto-landing (as in your case)
While we need more examples like yours to be 100% sure, I am right now fairly confident that this is the behaviour which DJI designed. And it does make sense.
Thanks for sharing and letting us learn.
Mirek |
