walter.koch
Hi everyone.
The DNG files produced by the Vision + camera can easily processed with Lightroom. I usually use Rawtherapee (4.2) instead which, however, has problems processing the files. The colors of the resulting images are distorted (too much red). I tried with other raw converters also, which all are based on the open source software "dcraw". Dcraw processing results in color distorted images when applying the embedded sensor matrix / correction profile. Disabling the embedded matrix (and also the camera whitebalance -> manual white balance) is needed in dcraw (and ufraw) to get correct colors. Disabling the embedded profile in Rawtherapee results in better images, but still there is some problem with color, that cannot be corrected usingm white balance.
Could you verify this issue, please. Does it need adjustment in the camera software / DNG file?
Best regards,
Walter
