hallmark007
Flight distance : 10017858 ft
Nick1 Posted at 2018-7-2 10:22
So I was under the impression that if you had GPS lock safe to fly status, the drone should not be flying away or drifting at all correct? Only in atti mode with no GPS lock. My IMU was in good status as well and I had latest firmware. Is there anything I'm missing?
You didn’t have any compass problem, if you did then aircraft wouldn’t react correctly to stick movements, but as you can see from your log when you pushed up and right that’s the way the aircraft went, whether you had a drifting problem is not possible from this log, drifting could be caused by a number of things, IMU weak gps, I’m sure your .dat file will show this better.
It’s pretty clear that compass issues where post crash as one would expect.
I do think this has a good chance of a warranty but can’t be sure.
