hallmark007
Flight distance : 9827923 ft
randy.sauder Posted at 2018-7-4 21:49
"Both your warranty and Care refresh clearly state that only if third party app causes crash will your app be null and void, both your care refresh are 100% covered in the event of aircraft malfunction."
Good to know ...however based on many user's experience, the above statement should be a major concern. It is likely that DJI Support may simply blame the 3rd Party App for any issue you may experience and deny any support and you will have no warranty .
I’m not sure if warranty is nulled by problem caused by app, I suspect they’re could be a problem if for instance , you are flying in a highly populated urban area or in the middle of the city and lose RC signal or GPS, these are not malfunction of the aircraft, and are caused by controller, much of this stuff is covered in the manual, so for third party apps I would presume it’s the same, i had asked a lawyer friend of mine to check out the very simple contract with Care refresh, which covers all aircraft malfunctions, his opinion on I think it’s point 11, dji will not cover Care refresh if crash is due to use of third party app, for him the clear meaning in this point was and considering other point unequivocally, that if using these apps you crashed due to aircraft malfunction you would have 100% cover.
I have never seen any case that was refused a care refresh because of use of third party app, I have only seen one on inspire where there was a crash using litchi , and there was no problem with warranty , because warranty is used in the case of aircraft malfunction and not care refresh.
If what your saying about dji not relying on flight data from third party apps, then those with care refresh should have no problems, as dji would have no proof as to what happened to their aircraft , and this would fall into the same category as accidental damage, IE dropping you Aircraft down the stairs , which is covered, and also comes without any data as to what occurred , but is still covered.
I also don’t believe there is some covert practice going on to disprove no aircraft malfunction. If you think about this one, a simple disgruntled employee turning up at the press core, to tell of shady unscrupulous practices at dji, would almost certainly do much more damage to the company than trying to dishonestly deny a customers genuine warranty.
Having said all that insurance is a tricky business, and it’s important we know and understand, what cover we have. |
