Bashy
Flight distance : 2354357 ft
Yep, what he says lol
You will need a device that has a least 3gb ram (nvidia shield K1 only has 2gb but works well) and a octa core cpu, if you want to stick with the Tabs, then the Tab S2 running android 6 is flawless, android 7 is problematic but workable. do not confuse the Tab S3 with the Tab 2 either, always check the spec, 3gb ram and octa core is minimum nowadays... |
