DMX_MT
Malta
More ISO means not exceeding ISO 800.
More Noise I agree, usually this is seen in Skies especially when Dark. This can be Fixed Post Processing. I do it all the time by applying 2 layers, 1 Layer with the Sky that is a bit Gaussian Blurred, then 1 Layer with the Normal Sky as the Original. I start lowering the Opacity of the Top Layer and blend it with the Bottom Layer to reduce the Unwanted Noise.
Less Sharp I don't agree, as with less ISO, the Shutter will need to remain open for longer and a slight movement will cause blurring and less sharpness.
