bob_angie
Flight distance : 321519 ft
Hello Mark,
The cable you're holding is not meant to connect directly to the focus wheel, that cable is intended to connect to the port right next to where you mount the camera. There's a little pull tab next to the lock and unlock lever of the quick release, if your camera is compatible, connecting it to that port will allow control with your Ronin-S. the function of the port directly only the focus wheel has not been revealed, I'm sure its purpose will be made available with further accessories. |
