Grumpy D
Flight distance : 18245 ft
All said. I don’t know the pin out on the battery but I can count. You only need two connectors to move power. One or two of the remaining eight could be to determine if battery is installed. If yes, it could be the Mavic is bad or simply be a bad battery. If you’re sure you are going to have a MA when this is sorted out and if your finances allow and if you have a local retailer run grab a battery, you’ll get one soon anyway so no wasted money. Plus you can fly while you’re waiting for DJI to send you replacement battery. If no joy with that you’ll still have the needed second battery when you get your replacement.
Tell us where you are, someone here may be near you and willing to meet up for a test. Best of luck. |
