Mark The Droner
Flight distance : 2917 ft
With no prop guards, it likely fell through the trees onto the ground. I'm speaking from experience :-D
I'm sorry to say it, but the odds of you finding your Phantom are not very good. Once I lost one in the woods and I knew exactly where it was. I had full telemetry signal and I also had a GPS tracker on it which was working perfectly. It was only about 1000 feet away from homepoint when it hit the trees. And it STILL took me four hours to find it. FOUR HOURS. My wife pulled 13 ticks off my legs. Another time I lost one about 400 feet from homepoint in the woods. I actually heard it hit the trees and fall into the woods. Had full telemetry and the GPS tracker. Took me a solid hour to find it.
You'd have to do some math. It was travelling 4 mph heading south flying backwards with 25% battery. So when did it hit critical battery? 10%? Do the math and figure out at what point it started to auto land. Then add some more southerly movement for the wind while it autolanded from 1000 feet high. Think about how much time it would take to auto land from 1000 feet high. The answer is it would take a long, long time to come down, drifting the whole way down. That's a huge amount of woods to search. It also could have shut off during auto land because it ran out of battery. These Phantoms are not engineered to do a critical autoland from a thousand feet AGL.
Consider a GPS tracker for your next one.
Good luck.
