KREMi
Poland
I can understand Your problem GDL - had similar experience.
on my maiden flight (middle feb.) of my air first few mins were ok. I was testing range, how it reacts (comparing to my spark, which I owned earlier) all did look ok. in CE got some weak range alerts after 300m, but was able to get to 500ish with laggy image. anyway, then decide to test sport mode near me. flying close range... and then it happen - maybe 20m from me...
no warning, link lost instant, red led on remote. drone did enter RTH after a moment. did wait thinking maybe it's some weak link, interference etc. - but no, link is dead, black screen in app, like drone not connected.
as last resort after some seconds did turn remote off, and on. and then it regain connection! (was already about to land 3m away from me, hovering 1,5m above ground)
I have vid somewhere which I was showing with that situation, maiden flight did rec with gopro. sadly got only flight records - did not think (and know) to get logs that time from drone, Remote etc...
did write to support, was told to reflash with cable/dji assistant (which also created much problems, as PC was not seeing air/remote, solved with some old drivers from old assistant version)
so after renewing firmware with cable, all was not bad - it did not happen till my last spain trip (may/jun) - then once had it again. link lost. no control. this time did turn remote off/on faster (experience... ;) and it reconnect.
from that 2nd incident - I try to fly normally - but I just don't trust this drone. and ofc all pre-start procedure is always taken, 11sat+, no interferences in sensor tab, recorded HP, was calibrated, etc
so there is something wrong with some units - I was not able to reproduce those situation (and i did try a lot after 1st time, doing same path, etc.)
on weekend when I'm back home I'll share my flightrecords and I'll find that video to upload/share
