Hi. I am sorry for the trouble. Please try to re-login your DJI account on the DJI Go application and make sure that you are not on beginner mode. After these process please test your DJI Phantom 3 Standard if it will still show the same result. Thank you.
Wie lange ist der P3S schon im Einsatz? Hat gerade mal 1,5 Km hinter sich,wenn ich richtig sehe. Welche Systemsoftware ist drauf und welche Go app Version ist auf dem Mobilteil?
Can you please try to set maximum flight distance on your DJI Go app. Just go to DJI Go >> click the 3 dots icon on the top right corner >> click the first icon on the left side corner and from there you can change the maximum distance under beginner mode. Please check the attached image below for reference.
Natalia,
Normally if i set the distance or height to 30 then the controller beeps 3 times and the app tells me the AC reached and the signal should not been lost.
