Master Wheels
7974 18 2018-7-17
djiuser_NIA4M9vm2OHs
Hi, has anyone out there purchased the Master Wheels?  I just got a set and I have a problem. As soon as I press the power button a screen comes on in chinese with only the words "Assistant 2" in english. I'm attaching a picture.  I have had no luck with customer support, they have no idea how to fix it. I have an 8000.00 dollar useless contraption in front of me and DJI CAN'T FIX IT, they suggested I return it to B&H.
master wheels screen
2018-7-17
proimages
Flight distance : 1004731 ft
Just a guess but maybe hook it up to DJI assistant 2 and see if you can run updates..adjust setting etc. cheers Darrin
2018-7-17
proimages Posted at 2018-7-17 15:57
I tried but there doesn't seem to be any communication between the app and the wheels. There is no literature about how to do this anywhere.  Thanks for the suggestion.
2018-7-17
Bandry
djiuser_NIA4M9vm2OHs Posted at 2018-7-17 17:32
I delt with this issue last night and the only fix that got me through it was taking a picture with google translate on each of the menu pages and finally finding a language adjustment.  I very much feel your pain in regards to the tech support on this product.  Clearly they don't know how to service the type of clients who purchase this product.
2018-7-19
Bandry Posted at 2018-7-19 14:26
Thanks, would you mind very much posting a step by step guide to how you solved this issue?  I'm sure other users would appreciate it down the line.  I'm about to start shooting a series and am getting another set sent to me which by the sounds of it will still have that problem.
2018-7-19
StUDJI2000
djiuser_NIA4M9vm2OHs Posted at 2018-7-19 14:56
This video shows you how to change the language on your DJI Master Wheels.
2018-7-20
StUDJI2000 Posted at 2018-7-20 23:32
This video shows you how to change the language on your DJI Master Wheels. Video link
Thank you!!!
2018-7-21
So, I got a new set of MASTER WHEELS to replace the old ones and I have the same issue as before. I cannot get past the screen in Chinese that only says in English:  Assistant 2.  I have the assistant2 installed in my macbook and I have connected the Master Wheels to the macbook via a USB-C cable that was provided.  Nothing happens.  Customer Service is useless.
I saw your video but my question is how did you get past the first screen in Chinese? What I saw in your video is your control screen already working.  I cant get past that. Did you have the same issue?
Thanks
2018-8-3
Fixed it!!!! finally.   They told me to use the wrong Assistant 2 so I found the Ronin2 assistant instead of the one they told me I should use.  All good
Thanks!
2018-8-4
fanscdfacd3e
Flight distance : 1128091 ft
Poland
Hi! Does anyone connect DJI master wheels with DJI inspire 2?
2018-8-28
fans3a2d2b46
djiuser_NIA4M9vm2OHs Posted at 2018-8-4 08:27
hi sorry but i have the same issue with thwe master wheels and i cant change the cines screen could you tell me how you did solve this problem
thanks emiliano
2018-9-24
fans3a2d2b46
Hi I have the same issue could you give me the link for the proper dji assistant
I think I’m using the wrong one like you thanks Emiliano
2018-9-25
djiuser_O1odh6wTILan
Hi ,I still have a problem to link dji pro wireless receiver with master wheels.User guide says on activation and linking:"press and hold the link button for two second to link to a controller" very easy up to here.Then says:"You must also initiate the linking procedure on the controller".
Now I'd like to know watta f***k I have to do to initiate the linking procedure on the controller, in which way can I initiate linking procedure on the controller?
is there anybody out there so kind to help me please?
thanks a lot in advance
2018-10-16
Alex D Sala
djiuser_O1odh6wTILan Posted at 10-16 11:25
is there anybody out there so kind to help me please?thanks a lot in advance
HI! u solved?? i've the same problem!! thanks
2018-12-27
LUMINARIO
Flight distance : 169925 ft
try and call DJI Burbank - basically your menu is set to chinese and needs to be set to English - can you go thru the menu?
2019-8-8
LUMINARIO
djiuser_O1odh6wTILan Posted at 2018-10-16 11:25
basically link the controller to the master wheels by binding that controller with master wheels - its not absolutely necessary but you get better reception with controller
2019-8-8
djiuser_bkjGTughBbKK
djiuser_NIA4M9vm2OHs Posted at 2018-8-3 20:54
Hey how did you get passed first screen? Thanks
2020-8-29
Rothercam
thanks for this,
please can you  tell me where you found the ronin 2 assistant, i cannot see it or it wont let me download it...
thanks in advance
2022-1-14
Rothercam
Rothercam Posted at 1-14 10:01
thanks for this,
thanks in advance
hey,
with some help from becky in dji i got this sorted. Every piece of kit from dji needs activated it seems. To activate the master wheels you need a windows computer with windows 7,8,9 on it they havent updated the apple software since 2019 i believe! plug the computer into your master wheels after downloading with this link
https://www.dji.com/uk/downloads/products/master-wheels
you need a usbc to usb which should be in the kit
the activation process is simple after this. follow video above to change the language
the ronin 2 and wireless receiver also need activated through this app. Ensure everything is on the same firmware and it should be straightforward.
good luck!
2022-1-21
