Phantom 3 Standard only getting 220 meters in a rural area
949 18 2018-7-19
macska_usa
Romania
Hello,
I have been experiencing range issues with my Phantom 3 standard. The DJI GO software reported strong interference every time I tried to calibrate my compass and many times failed to do so. (3/5 times) I am flying in a rural area, where I'm getting horrific range, around 50-60 meters at an altittude of 15 meters. There is a cell phone tower less than a kilometer away from me and several wifi networks just in range of my take off point. The furthest I have managed to fly it so far was 220 meters, which was a rare occasion, to say the least. So far I haven't tried flying in an other area, but I will soon.
Also, I am not that familiar with drones in general, I don't know what is considered an "interference free area". Is that an area without cell phone signal or without WiFi Signal?
Besides that, I also do not know if there could be something wrong with my drone. Support is currently unavailable, that's why I turned to the forum. I bought my drone 2 weeks ago, so I don't expect anything to be wrong.
Thank you for your help
2018-7-19
Mark The Droner
Flight distance : 2917 ft
Are you sure you're aiming the controller/antennas correctly?
2018-7-19
DJI Gamora
Hi, thanks for reaching  DJI Forum, we do apologize if you are having issues with your aircraft. You did mention that there is a cellphone tower less than a kilometer away, this wall signal jams and your compass will be getting error messages. If I may ask you as well for the brand or make of your mobile device where you downloaded the app. Thank you.
2018-7-19
macska_usa
Romania
Mark The Droner Posted at 2018-7-19 11:34
I don't know how to do that, and haven't even bothered adjusting them so far.
2018-7-19
macska_usa
Romania
DJI Gamora Posted at 2018-7-19 11:36
I have an iPhone 7 Plus with the latest iOS firmware. I downloaded the App from the official app store.
2018-7-19
DJI Gamora
Hi, unfortunately, the iPhone 7 plus is not yet fully compatible to run the app. Please see the list of fully compatible devices below. Thank you.
2018-7-19
macska_usa
Romania
DJI Gamora Posted at 2018-7-19 11:45
[view_image]
I have also tried using an LG G6, which provided the same results.
2018-7-19
macska_usa
Romania
macska_usa Posted at 2018-7-19 11:47
Looking at the recommended devices, I realized that the iPhone 6s is listed (which I own). By how much will using a fully supported device improve my current situation?
2018-7-19
DJI Gamora
Hi, LG G6 is not also supported, the phones that are not listed are currently under testing and development stage. Thank you.
2018-7-19
macska_usa
Romania
DJI Gamora Posted at 2018-7-19 11:53
I realized that I own an iPhone 6s, which is fully supported. By how much will using a fully supported device improve my current situation ?
2018-7-19
NM_Quad
macska_usa Posted at 2018-7-19 11:54
It is fairly important to use the mobile devices listed on the DJI website or in post #6.  These are the ones tested by DJI to be fully compatible with the GoApp.  Others may appear to work, but some functions won't work or other problems not obvious.  Many post over the years on that.  On your antenna, ensure your stick antenna is fairly vertical to be somewhat parallel to the Phantom landing legs where the Phantom antenna is located.  There are also antennas inside the remote control unit you can't see.  For these reasons, always ensure you and your control unit are facing the Phantom at all times to ensure proper connectivity.
2018-7-19
DJI Gamora
Hi, a fully supported phone will optimize the performance of your drone. There may be cases like it won't work but this is only if there is an upgrade or update on the app or in the firmware of the aircraft, though everything will be showing on the app since its a supported phone.
2018-7-20
macska_usa
Romania
DJI Gamora Posted at 2018-7-20 03:10
In case I will still experience the same issues, do I have to RMA my drone in order to get a replacement ?
How can I tell if the antennas in my remote controller/drone are damaged ?
2018-7-20
DJI Gamora
macska_usa Posted at 2018-7-20 06:21
Hi, if you want to send the device for repairs, just click the link below to fill out the form. If the antennas are bent or loose are considered damaged already. A drone has a crack to its shell and the motors are inconsistent when running or having a hard time to spin are also considered damaged.
Online Repair Request
2018-7-20
WD9EON
Flight distance : 686886 ft
I recommend you download the manual from DJI and read it.  It will give you information required to fly your drone and what to expect from it.
2018-7-20
Texas-Mark
Flight distance : 23002 ft
Maybe a silly question, but have you turned off "beginner mode" (or whatever it's called that limits range)?
2018-7-20
Peterx
Flight distance : 1499708 ft
Texas-Mark Posted at 2018-7-20 13:52
How the P3S get 220 meters if the beginner mode is in?
May be it´s more a sender receiver issue.
2018-7-22
Lonesome Crow
Flight distance : 406076 ft
Could I suggest this video, I am not that familiar with drones in general,.  Being that you stated "I am not that familiar with drones in general," this might have some useful information for you.  Before I got my Phantom 3S, I bet I watched this video half a dozen times.  Good information here might help you solve your issue.  Lot of good folks here willing to help you.  Happy Flying!
2018-7-22
Peterx
Near a cell tower i did´nt any message of compass error but on the opposite direction of my house i got it more because i ´ve flown my AC very close to an old ore mine. But it was not so serious as i though.
2018-7-22
