Good morning i have just updated the phone, rc and spark drone with the new software firmware.
Although the phone HUAWEI MAte 9 connection with OTG cable works as usual , i found out that there is a proble with my tablet.
I have the huawei media pad T3 8 inch . Before the update the OTG cable was working perfectly ans without problems.
After the update of firmware the OTG cable connection doesnt work . For your information, when I connect the RC with the Tablet via OTG
the tablet doesnt recognize the RC as it hapens with the phone.
Hi there. We are very sorry for the inconvenience. However, the Huawei media pad T3 that you are using is not fully compatible with your Spark. I highly recommend you to use a fully compatible device on your Spark to avoid any issues when flying. For reference, you may check the attached image below for the compatible devices on Spark. If you have any other concern, please let us know. Thank you.
DMX_MT Posted at 2018-7-23 05:11
Watch this Video Tutorial Mate, Try this Method just to be 100% sure, although I think you know how to connect it -
https://www.youtube.com/watch?v=SR9T0aiIoOc
Hello again
I tried to connect with the video instruction and my tablet didnt worked.
i thing that this is a proble of firmware because before the update i had connection on my tablet
How can i Install the previews version of firmware?Is this a good idea ?
@thagiam, did you make any progress with this issue?
I'm having the same issues with my T3 8inch and the Remote... OTG is just charging my tablet thats all it does...
S1m0n Posted at 2018-8-29 00:39
Hello
with the latest firmware upgrade both Mobile phone Huawei Mate9 and tablet Huawei T3 didn't work.
I downgrade the firmware in the copter and now i have perfect OTG connection in mobile phone but NOT in the tablet.
I assume that there is a problem and when i connect the rc with the tablet via otg, the tablet recognizes the tablet as a charging device. The usual pop up message for USB use as a transfer files photos doesn't work .
For the record the usb connection of the tablet enables the pop up when i connect a usb stick with movies.
I am having a similar problem my Huawei MediaPad t3 7 works perfect with a Phantom 3 on wi-fi, but my spark connects on wi-fi and otg cable it shows Telemetry if I lift the spark the altitude varies but nothing from the camera, has anyone managed to get this Tab working with a spark.
