No image transfer
472 16 2018-7-23
Shustenko
Russia
Hello there is no image transferring. Don’t know what to start fixing.
2018-7-23
Texas-Mark
Flight distance : 23002 ft
Can you be more specific? Are you connected to the drone's wifi and not something else?
2018-7-23
Shustenko
Russia
Yes. I have stable WiFi connection. I can move drone. But there no video
2018-7-23
ALABAMA
Flight distance : 10442687 ft
Has your P3S been involved in a crash, or hard landing?
2018-7-23
WD9EON
Flight distance : 686886 ft
Make sure you have a valid SD card in the camera.
2018-7-23
Shustenko
Russia
Do I need SD card for stream?
2018-7-23
Shustenko
Russia
Probably I had some hardship landings. But visually it seems normal. No damages
2018-7-23
DJI Stephen
Hello. I am sorry for the trouble. Can you fly the aircraft in different places next time? There may be a strong interference source in the environment you are flying in.
2018-7-23
ALABAMA
Check your flat ribbon cable for nicks or breaks.  Also unplug the multi wired pin on top of gimbal, then plug it back in.
2018-7-23
Shustenko
Russia
DJ Stephen: I tried it in several places
2018-7-23
Shustenko
Russia
ALABAMA: I will try this pin...
2018-7-23
G_Sig
Flight distance : 9109311 ft
Iceland
Shustenko Posted at 2018-7-23 15:24
You can move camera and start motors with CSC command without WiFi if the controller is connected to drone. Post a screenshot of your device.
2018-7-23
WD9EON
Shustenko Posted at 2018-7-23 15:29
No, but you can't do anything with it.  No photos or video can be recorded without the SD card in the camera.    You can probably do a screen capture if the video is live from the drone, but it will be poor quality.
2018-7-23
Peterx
Flight distance : 1499708 ft
Are you sure to be connected the right SSID of WIFI named as Phantom3_xxxxxxxxx yet?
2018-7-23
Shustenko
Russia
In aircraft status: gimbal disconnected
2018-7-23
DJI Wanda
Shustenko Posted at 2018-7-23 15:46
Hello there. Sorry for the late response. Do you have a screenshot of the error message?
2018-7-25
Shustenko
Russia
Yes I have the error screenshot
2018-7-25
