Aardvark
Flight distance : 384432 ft
Perhaps I could provide an answer.
In ATTI mode (where no GPS/GLONASS lock, and no VPS (bad light) ).
In this mode the aircraft does not know its position, it will hold its attitude or level steady, and also its altitude (using onboard barometer). It will adjust the motor speeds as needed for it to hold the aircraft level, and at the altitude indicated by its barometer, in doing so it pays no attention to the position (as no GPS at this time). So by the time the errors in IMU level and barometer inaccuracies (also errors in motor adjustments) are taken into account, this will cause some drift or change of position. At least, that is my understanding :-) |
