I had the same problem. Turns out that there is a very simple fix.
Just follow these directions and you'll be fine:
1) Turn on your Drone
2) Use a very pointy pencil to push the little red LED button on the undersurface of the drone. This is a little 4mm hole under the right back side of the drone. It usually has a small red LED light in it. When you push this in, it will put the drone into "bind" mode.
3) Turn on your new transmitter and wait about 10 seconds. Your drone will then bind to the new transmitter.
4) Turn off the drone and your transmitter
5) Uninstall your old Phantom PT2 software
6) Download the latest Phantom PT2 software from the DJI website at this site: http://www.dji.com/product/phantom-2-vision-plus/download and install it on your computer
7) Connect your drone to your computer via USB
8) Start your Phantom PT2 software (see photo attached below)
9) Go to the "BASIC" tab
10) Down below, you will see "Transmitter Version". Select "upgrade version".
11) Wait about 5 seconds, then disconnect your drone and quit the software.
12) Power down your Drone.
Basic Settings on Phantom PT2 Software
You will now be good to go!
