Oldmaninwva
Flight distance : 9750253 ft
solentlife Posted at 2018-8-8 04:03
Sorry -wrong for good reason ...
"if he stopped a flight at 70% which would be in the neighborhood of 3.8 volts and auto discharge is set for 7 to ten days then 3 days later if he decided to use that 70% battery he would still have 70% charge.. 3.8 or so Volts., he could easily get 10 to 12 minutes of flight to get a few shots."
Nigel.... I decided to do an experiment to prove one way or the other to myself about what I was getting at on these Phantom batteries... Now I only did this on one battery, over 1 year old, it had 60 recharge cycles and was very healthy. Set for auto discharge at 10 days. I charged this battery up on a Sunday afternoon (8/5/18) and on Thursday morning I inserted it into the P4 and turned the screen recorder on before turning the P4 on. I have these recordings but do not have the time to edit them down just yet.
The battery level on immediate startup when it showed was at 99%, total voltage of 17v, cells had 4.27, 4.27, 4.26 and 4.26. At this point I decided to just turn the motors on and let them spin to run the battery down, after 20 some minutes I returned to find the remaining battery level at 80%, with total voltage at 16.3v and cells at 4.08, 4.08, 4.08 and 4.07.
I removed the battery and set it aside from that Thursday morning to this morning, about an hour shy of a full 3 days in a partially discharghed state. Once again I turned on my screen recorder and inserted the battery. When the battery level displayed it still showed a level of exactly 80%, however the one cell that showed 4.07v now shows 4.08. The battery did NOT drain in any way. I then proceeded to FLY the P4 at that point and had over 12 minutes of flying around before landing it at 36% charge. I would have flown it a while longer except I needed to answer the phone and I do not like distractions when I’m flying. There was also no abnormal power level loss while flying like was suggested would happen by several others.
So.... I’m not sure what YOUR batteries are doing to make you say the things you and several others do concerning the original posters desire to fly on a partially discharged battery, but MY battery works JUST like I had stated several times in all of that dialog.
I will state one thing again that I had earlier, I KNOW what’s my equipment is doing as I fly ALL the time. I know when a battery is not up to par so I start looking at cell deviations to see if I have the beginnings of a failure.
So I stand behind my original statement that for the purpose of what the original poster wanted to do, IF he has healthy batteries then he would have NO problem taking a partially charged battery and put his bird in the air for a quick shot or 2.
No it’s not considered something you would want to do all the time, but in MY opinion the risk for a great shot could be VERY well worth it.
Not trying to prove anybody wrong really because all you guys might be having some battery issues, what I did was for myself, cementing the fact that what I said is true... for MY batteries |
