solentlife Posted at 2018-8-13 04:43
Bad wording ... common sense .... c'mon ....
I wish you good luck because I fully expect that your LiPo's will fail a lot earlier than another persons who treats them better. Your treatment of your LiPo's is literally just following the old NiXX road and detrimental to LiPo format. 80% for a 18 month old pack is not good at all ... I could accept if you literally flew that same pack literally every day ... but even then its not good.
It's a loosing battle with you Nigel. Obviously you do not know the difference battery life (I call it capacity or memory) and charge level. My charging level is 100%. My battery life is 80%. Look at the manual so you will know the difference. Page 31 of the P4 Manual
Checking the Battery Level The Battery Level Indicators display how much power remains. When the battery is turned off, press the Power Button once. The Battery Level Indicators will light up to display the current battery level. Battery life Battery life refers to how many more times the battery can be discharged and recharged before it must be replaced. When the battery is turned off, press and hold the Power Button for 5 seconds to check the battery life. The Battery Level Indicators will light up and/or blink for two seconds, as shown below:
