MikeNoDroneX
Flight distance : 249829 ft
Brazil
For some reason unable to create a new thread so Ill use this one
I am extremely dissatisfied with DJI support so far
I've lost my mavic 2 weeks ago due to what I beleive to be an issue that should be covered by the warranty
Opened a case (took 3 days, asked for the same details 3 times)
Sent all logs 10 days ago.
Got multiple "Thank you for your patience reply, will take 2-3 days to get a real reply" when I checked up but no real response
The only real response I got 4 days ago was a recap of the flight log (duh, I can see it myself) without addressing the actual issues I brought up
Responded again with further questions and what I beleive the core reason for the loss, and got no reply yet
Hi
I disagree with your analysis.
1. The wind was about 20-22 knots (~35-40kph). In sports mode the speed is around 65kph. I had no issues piloting it.
2. As you can see from additional flight records that I’ve sent, on the days before I have flown in similar conditions or even stronger wind without any issues
3. At T=08:13, the battery indicator was on 60% remaining. I assume you can see it in the flight record.
4. Why did the app record ended at T08:13? On the RC I got a message saying ‘Remote controller connection error’.
This is a malfunction of your device and the #1 issue here that needs clarification
Did you examine the RC records that I’ve sent?
5. Why did the aircraft did not return home? The kitesurfer I was filming saw it from the water going up to a high altitude after the video got stuck and the remote control stopped responding.
I am sure 60% battery is enough to go 223 meters in sport mode..
This is a malfunction of your device and the #2 issue here that needs clarification
Waiting for your response
Sent: Friday, September 21, 2018 4:53 AM
To: Mike Postel <mike@menahel4u.com>
Subject: CAS-2259099-X0C5M8 CRM:0409000006999
Dear Customer,
Thanks for your patience.
This is Dora from data analysis team, and I will be assisting you on this case from now on for related inquiries about data analysis.
For your claimed case CAS-2259099-X0C5M8, we have already finished the analysis, and the result is as follows:
1. The GPS signal was fine and the aircraft worked under Sport mode;
2. T=00:32, H=44.5 m, D=15.4 m, the app warned that there was high wind;
3. T=02:50, H=44.5 m, D=4.8 m, there was no pilot's input but the aircraft tilted 21.7 degree rightwards when it was hovering, which indicated that there was high wind from the east affecting the aircraft;
4. The aircraft could not return home normally as it was affected by the high wind, and the battery would be consumed fast;
5. T=08:13, H=9.3 m, D=223.5 m, the app record ended;
6. The takeoff point: -3.2374368 -39.2321324, the end point: -3.2355674 -39.2313686.
According to the analysis, the incident happened due to piloting the aircraft under improper flight environment. Please do not fly in high-wind condition.
Should you have more questions about the result of the data analysis, please reply to this email directly within 15 calendar days. Then we will contact you via email in 2-3 working days.
Thanks for your support. Have a nice day.
Best Regards,
Dora
DJI Tech Support
Flew the dji mavic pro platinum today at the beach filming kitesurfing. This is the 3rd time im doinf it. 2 batteries each time. Wind around 20knots. Previously flew in higher winds without an issue. Flew in sports mode more or less 400meter radius standing directly on the beach with the kitesurfer upwind of me. Height of 10 15 meters above water.
After about 10 minutes into the 2nd battery got a message on the screen 'remote control connection error'. Image was stuck. At the same time aircraft went up to 30+meters as seen visually by the kitesurfer. Pressed the home button on the remote itself several times. Tried restarting the phone and the remote. Checked the usb. Nothhing. The remote at some point showed on its display height of 68 meters and distance of 200 meters. Tried returnong it manually. Distance changed but wasnt consistant. At some point height showed zero and thats it. Guess it drowned.
