P3 crash
jorski
Flight distance : 171946 ft
Finland
http://www.phantompilots.com/thr ... record-video.42904/
I am quite worried about... so far I have not got any problems with my P3A
2015-5-24
mswall
Flight distance : 39695 ft
what settings were you changing when it lost control?
2015-5-24
marco0002.telen
Flight distance : 2079551 ft
Belgium
Hi it seems your setting turns from p-gps to atti  a couple of times at the moment of the strange behavior.
Dont know if this is what caused it, good luck getting in the air again.
2015-5-24
jorski
Finland
It is not my Phantom. I just bring this post here...
2015-5-24
Tahoe_Ed
Flight distance : 2605 ft
We have asked him to send the unit in for repair/replacement.  We need to read the Flight Data Logs to see what happened.  The stick movements are odd.  From the video of the App flight playback he is 100% on the sticks more than once .  I certainly don't fly that way.  We will have to wait and see what the Log file states.
2015-5-24
Ulysse
Flight distance : 1389931 ft
Belgium
Do you mean going 100% on the sticks can lead to a crash ?! I sometimes go up at 100% stick so it is dangerous for the quad's health ?
Most of the times I fly very smoothly but be serious : if the quad cannot afford 100% stick movement all DJI quads should be grounded !
Did you see the vertical speed during the fall ? It ends with a 56mph vertical speed without any stick input.
2015-5-24
mountmotor
I am 99.99999% sure that this was a compass issue. Notice how it falls out of GPS to ATTI... Once the orientation goes it is very difficult to control in P mode....Immediately switch it to ATTI mode and bring her home ASAP. This has happened with some Inspires...Is it a defect? Possibly but there is also a BIG chance that the calibration either was not done properly or the IMU numbers were off the charts! Always check your IMU numbers before each flight!
2015-5-24
