RedHotPoker
Flight distance : 165105 ft
Read this article, which tells about a useful plastic adhesive product called Bondic.
http://www.lemondrone.com/drone- ... eres-best-glue-fix/
- INCREDIBLE ADHESIVE - When fully cured Bondic is 100 percent waterproof and is also heat-resistant. Dries clear and can be sanded or painted after it is hardened. Non toxic
- UV LIGHT ACTIVATED - The incorporated LED UV light has an easy press button and when the liquid is exposed to the UV light it cures in seconds to a permanent bond
- BONDIC IS NOT A GLUE - The formula stays liquid until it is hardened by UV light which means there is no chance of drying up in the container
- BOND, BUILD, FIX AND FILL - plastic, wood, metal, PVC, steel, rubber, wiring, ceramic, figurines, vinyl, Kevlar, polypropylene, leather and so much more
- COMPLETE STARTER KIT - Includes everything needed to start fixing: applicator, LED UV light, TWO 4 gram tubes of LED curing liquid
RedHotPoker |
