fans46953ebc
Flight distance : 765233 ft
DJI Susan Posted at 2018-8-8 20:20
Hi Marcel, just to verify, what's the current version of the aircraft firmware and App version? You may try to restore the CS to factory settings to see whether it helps.
Hi Susan,
The version of the DJI GO app is 3.1.38
The Inpire is on version v1.11.1.50 (it says is up-to-date)
I will try tommorow to restore the factory settings.
Can you tell me if it is possible to use the CS with the Inspire one pro without problems?
I dont mind to tweak and test but i want to know if it is possible the CS can work without issues with the Inspire one pro.
