DJI Ronin S Vibrate and mini Shake
12
47053 62 2018-8-7
bigds5555
sound like not quite balanced completely. I had this problem, restarted balancing from square 1 and it fixed problem
2019-1-1
DJI Susan
BJ42 Posted at 2018-12-28 11:54
Here is a video of the footage with 16mm vs 35mm just in case you wanted to see it.
https://www.youtube.com/watch?v=BKtDzLaw_-I&feature=youtu.be
Hi BJ42, I just realized that Mindy has responded you in your own post: https://forum.dji.com/forum.php? ... p;page=1#pid1697428 Please kindly check the latest response from our engineers and keep us updated there, thanks!
2019-1-2
DJI Susan
Well received, for your situation, please try to auto tune and recenter to check the motor parameters. If the gimbal drifts when shooting still, please do system calibration and joysticks calibration to see whether it works.
2019-1-2
BJ42
DJI Susan Posted at 1-2 03:45
Hi BJ42, I just realized that Mindy has responded you in your own post: https://forum.dji.com/forum.php?mod=viewthread&tid=175386&page=1#pid1697428 Please kindly check the latest response from our engineers and keep us updated there, thanks!
Awesome, thank you very much Susan.
2019-1-2
DJI Susan
BJ42 Posted at 1-2 06:17
More than happy to help.
2019-1-3
GeorgeMC
Flight distance : 90515 ft
DJI Susan Posted at 1-2 04:13
Thanks Susan
It seems like the system calibration might have worked.
It appears to be much better now
Thank You!
2019-1-3
DJI Susan
GeorgeMC Posted at 1-3 14:21
Thanks Susan
Glad to hear it helps. Wish you have a good time!
2019-1-6
fansa7bb1372
India
DJI Susan Posted at 2018-8-8 23:38
Hi there, we're sorry for the troubles. May I have a short video of your operation? We'd like to check the exact status and try our best to help.
Same issue is happening with me....i am operating my canon mark 3 and its motor starts shaking random times.....moreover when i walk to have some shots my camera shakes horizontally pls help me
2019-1-20
DJI Susan
fansa7bb1372 Posted at 1-20 00:35
Hi there, just to verify, the gimbal camera is balanced properly? If yes, you may try to calibrate the auto tune and see whether it helps.
2019-1-21
gmanthegman
Belarus
DJI Susan Posted at 1-6 22:59
Hi there!
I have exactly same situation. The camera shakes sideways and the overall image is not stable enough, no matter how hard i'm trying to ninja walk.
I tried auto tune, all the recalibrations, nothing worked.
2019-2-14
Kanaye Shogun
Flight distance : 335062 ft
Croatia
gmanthegman Posted at 2-14 09:55
Hi there!
I have the same problem...but just on the pan axis. I've tried everything. I will take my Ronin S to service next week because a video is unusable .
2019-2-15
Kanaye Shogun
Croatia
Hi there!
I have the same problem...but just on the pan axis. I've tried everything. I will take my Ronin S to service next week because a video is unusable.
2019-2-15
DJI Susan
Kanaye Shogun Posted at 2-15 11:52
Sorry about that. Hope everything goes smoothly. If there is anything else we can help, feel free to contact us.
2019-2-18
DJI Susan
Hi there!
Sorry for the late response. Just to verify, all screws on the Gimbal have been mounted tightly, right? Does the gimbal shake when it is in still status? It will be better to upload a short issue video, we'll double check, thank you!
2019-2-18
gmanthegman
Belarus
DJI Susan Posted at 2-18 23:05
Hi there, again.
All the screws are mounted tightly. There is some shake when I'm just holding the gimbal, but it gets very obvious every time I try to walk. After some recalibrations and autotunes, the shaking seems less vivid, but it's still there.
Here is the video.
https://drive.google.com/open?id ... d4Cd1vRg96xAFckmcEQ
Overall, the gimbal acts unpredictably. The shake does have a presence, yet in different amounts.
I use only one camera/lens setup and it seems balanced perfectly.
2019-2-22
DJI Susan
gmanthegman Posted at 2-22 23:14
Hi there, again.
May I know which camera and lens do you use? If the gimbal shakes when just holding it, you may re-balance and check again.
2019-2-24
gmanthegman
Belarus
DJI Susan Posted at 2-24 20:10
I'm using Fuji XT-3 with 23mm. It looks like I've been balancing it perfectly based on numerous tutorials and my own experience. The camera and lens don't have image stabilization, but still I could get a better result with the other non-stabilized camera and gimbal.
2019-2-25
DJI Susan
gmanthegman Posted at 2-25 04:58
Generally, the Ronin-S can be stabilized when being used with cameras that weigh less than 3.6 kg, with a width smaller than or equal to 205 mm, and a height less than or equal to 150 mm. If this case only appears in this camera, you may consider balancing weight or similar to check.
2019-2-27
yadha.studio
Iran
Hello
I just bought Ronin S
I first updated Ronin with the latest software
I have a Canon 80D -  24mml 2.8 lens.
The device vibrates after it is turned on.
I know this is because of the light weight of the camera
What should I do to fix this problem?
2019-10-17
tai_mingle
Same issue here. I have balanced it to the best of my ability (with a Canon 5D Mark iii) and the roll axis vibrate like crazy. Latest software, excellent balance. Don't know whats wrong.
2019-11-14
Max Mar
Flight distance : 453271 ft
DJI Susan Posted at 2019-2-24 20:10
I have the exact same problem with the Ronin SC camera XT3 18-55 lens, on the roll axis. I have these micro vibrations. The gimbal is perfectly calibrated. What can I do? Since August, no firmware has been able to solve the problem. Help me
2020-1-19
Max Mar
Max Mar Posted at 1-19 00:41
* micro shake image
2020-1-19
Bambasik
Hello !
I hope I can bring the thread back to life. I recently bought the Ronin SC combo Pro. Juhhhu!!!
Well, after balancing and auto tune I start to recording like quentin tarantino to create an unexpected twist...
I saw the movement fluently on the camera screen and felt a tingling of joy ! Cut ! Done!
Finally, when I editing the recording material on the computer I noticed a shake or vibration on the image when I was following an object like a Ninja (you can see that well when you look to sides of the moving image - you see an vibration or something like that)
is that normal ? Shouldn't it look completely fluid? What kind of fine adjustment should i set and which axes are decisive?
I use; A6300 + E 50 mm F 1.8 OSS
Please help. Thank you!
2020-11-3
12
