gregg1r
The connection for the battery charging is two gold colored male blades, 5/15" long, by 5/16" wide.
You'll need to verify the polarity of the battery and connections or you'll make it toast., burnt toast.
DJI doesn't recommend charging both the battery and controller at the same time, the Pro model has a 100 watt charger verses the Advanced having a 57 watt version.
Me personally, I don't see an issue with charging both battery and remote at once if you have the 100 watt charger. |
