DJI Susan
Hi there, the firmware does not work on Mini SE. If this error existed on Mini SE, please check the followings:
1. Check and make sure that the propellers are installed properly. The propellers with an arc mark must be installed on the frame arm motors with an arc mark.
2. If the in-app beginner flight tutorial is used, exit the tutorial and try again.
3. Check the GPS strength in the app. If the GPS signal is weak, try to take off the aircraft in an area where the GPS signal is strong. Ensure that the propellers are in normal condition.
4. When the GPS signal is strong, calibrate the IMU. You can go to Settings>Safety>IMU Calibration and perform calibration following the on-screen instructions.
5. Restart the aircraft.
6. Please check the aircraft firmware version and DJI Fly app version. If there is a new version available, please update to the latest version and try later. If there is no new firmware available, it is recommended that you refresh the firmware again to see if it can be resolved.
If the error persists, may I know if the drone experienced any impact damage previously? If yes, you may need to send the drone in.
You can click https://www.dji.com/us/service/repair to start an online repair case. |
