HedgeTrimmer
You can check for Magnetic Interference two different ways:
#1) using GO-4 App
________________________________________________________________
How to get ready:
Under main menu of GO-4 App - in middle at Top of Screen - Tap on QuadCopter Icon
At bottom of MC Settings screen - Tap on Adance Settings
At bottom of Advance Settings screen - Tap on Sensor State
At top of Sensor State screen - Tap on Compass
Below Interference, you should see two compasses for Mavic Pro, and one compass for Mavic Air
Blue dot next to Compass (1 or 2) indicates which one is being used in case of Mavic Pro
Checking for magnetic interference:
After powering up your drone, and it completes startup. What you want to see {and not see} at your chosen takeoff spot
You want to see short 'Green' bar(s). {You do not want to see 'Red' bar(s) at all. And it is best you do not see 'Yellow' bar(s).}
Link HERE
#2) using 3rd-Party Apps available for Android & iOS SmartDevices
All you need is a Smartdevice (iPhone, iPad, Android phone or tablet) that you can download and install one of several Tesla or Gauss magnetic field strength Applications on.
What makes this method easy is all you do is walk around area, observing magnetic field strength. No need to walk straight line with digital compass or align your smartdevice running GO-4 with direction your drone is facing, then check GO-4 compasses.
If you observe any major field strength changes upwards or downwards, usally reported in Gauss or µT (micro Tesla), you avoid that spot as possible takeoff point or area for compass calibration. If you are going to takeoff from within that area, last step is to check your chosen takeoff spot. Done by lowering Smartdevice down to ground, then moving smartdevice around spot looking for any changes from what you previously observed over the area. This last steps checks for buried ferrous metals (aka rebar, steel pipe, scrape metal) and underground power lines.
At link below are example screensnaps of two different Apps showing deviations from Earth's magnetic field by different sources of magnetic intereference.
Link HERE
