Nigel_
Flight distance : 388642 ft
COPILOT VATER Posted at 2018-8-13 14:42
MY HARDWARE IS UP TO DATE CANT UNDERSTAND WHY WOULD IT MOVE 1/4 TO 1/2 INCH AND ALSO PURCHASE TWO BOXS OF THE 9455S L LOW NOISES IF ANY YOU GUYS IF YOU CAN HOLED THE MOTORS THEN MOVE THE PROPELLER BLADES SEE IF IT MOVES WITH YOU THX VATER
A small amount of movement is normal, as long as they are locked into place and have to be pressed down to unlock them then there should be no problem.
1/4 inch is a bit much, I would expect them to come off with that much but maybe I don't understand. 0.25 cm at the tip I think is normal.
A picture of the cuts would be good to see.
