CA Mavic Pro
Flight distance : 639652 ft
Lebanon
Hi Amjad, Better not to take off from balcony, it is tricky and you'd be looking for trouble. I've done it a few times, if you move the drone to the very end of the balcony you might get GPS coverage (do NOT attempt to take off without GPS lock), in that case to take off from a table so that you can move the drone away quickly without having to hover around the balcony (remember to check the compass and IMU before taking off). When landing, you shouldn't try to land back on the table but instead free up as much space as you can and land quickly on the balcony (remember the drone can lose GPS quickly and even when there is GPS coverage its not 100% stable and moves +/- 1m). If you are having trouble with OA, you can consider to land it backwards. When doing all that also remember that if you lose signal, the RTH factory settings the drone is likely to crash above your head, so make sure to set all parameters correctly. I might have missed other risks you may encounter, so again avoid flying from a balcony if you can. |
