Was updating the firm ware in my spark by connecting the spark with the mobile using dji go 4 app via Wi-Fi ... during the course of firmware update up to 99 % the Wi-Fi connection between the spark and mobile was diasconnected , after all this hassle the drone turned off , didn't turn on ever again but the middle two led indicators out of the 4 leds in the battery are lit continuously even after the battery is removed from the drone... Please help
Do you have a second battery? Try that one, please
Are you on android or on iOS?
Anyway: for updating the firmware of the drone use dji assistant 2 and a usb cable from the computer to the drone.
good luck!
Hi, I do apologize for the inconvenience caused. May I know if you have other battery that we can try to test to your AC? Also, could you please try to update the firmware via DJI Assistance 2? You may watch the video tutorial below for reference. Should you have other concern, please let us know. Thank you.
