RicardoGray
Flight distance : 4356421 ft
solentlife Posted at 2017-10-4 09:29
First thought that comes to mind ... RTH depends on having a GPS recorded Home Position ... and at point of activation of lost signal - a GPS location then to know how to get home ...
So my question will be - how can RTH even start to work if indoors .... and GPS mode switched of ?
Ah, you have a good point. I guess I had an experience where I was inside of a large building, not exactly in my house if you will, and it was a metal one. The aircraft did capture a couple satellites when I move close to the overhead doors, and then would drop out as I moved around inside. I was flying in ATTI mode though. I guess maybe I was more thinking about "loss of signal" and not RTH. But I agree with RTH you need to have GPS, but would the signal loss automatically try trigger a RTH or just do nothing? I realize the lost signal is highly unlikely, but just thinking out of the box.
Edit: Trying to remember my filming in the large building I was referring to. After thinking about it (it was a couple years ago and haven't done it since), but I remember taking off outside and then flying in thru the larger overhead doors. Which it would have established a home point I'm sure. I remember I turned the RTH action to just hover thinking of the situation I described, but now I wonder if I had lost signal what could have happened??? I'm guessing now thinking more about it, the logical answer might be that if no GPS is available, the aircraft would just hover until it regained the signal right? And if flying in ATTI mode anyway, probably would not initiate a RTH. Over thinking this! |
