Labroides
Flight distance : 9991457 ft
fansed5d1cc0 Posted at 2018-8-21 20:02
I don't know the cause. There is a problem with the DJI Go 4 app, its been covered in many many threads. Obviously some people need to set the home point to the controllers location hence the feature in the app. It's not like they removed that feature. It works fine with an android phone. The GPS in the apple iPad Mini 4 is working properly. All other apps on this same iPad find and use the location correctly.
I don't know why the DJI go 4 app does not accept the iPads GPS coordinates. The signal from the GPS is not weak, but the DJI go 4 app thinks that it is . Using GPS diagnostic software shows that there is a strong GPS signal and the iPad's gps system is working properly. Yet features in the DJI go 4 app that require GPS from the display device do not work reliably.
What happened to the accuracy issues you mentioned?
As I was hinting, it looks like the app can't find any GPS location data.
The signal from the GPS is not weak, but the DJI go 4 app thinks that it is.
There's no such thing as weak GPS signal. When DJI say weak GPS signal, they mean no GPS signal.
As the actual status of the iPad's GPS system is critical to the issue, can you show a screenshot so we can see what the GPS app is indicating?
Why are you wanting to reset the home point to the location of the controller?
There are very few situations where this would be necessary and in most of those, it's just as good to use the Phantom's current location as the controller's. |
