ZukySpark
Flight distance : 226066 ft
Portugal
Hello
The image quality is good, even on bright days the screen gets good contrast. I think spark stream at 720 HD and no 1080, so expect good quality streaming but no a movie quality
But if you compare with that goggles of VR where you place your mobile inside it the DJI goggles are much much better.
The Head tracking works great... even on gimbal even on horizontal ( the spark rotates in is axis) there are some functions when you connect the spark that became disable, maybe it works on Mavic.
The longest distance i had with goggles before automatic RTH (losing connection) in Portugal is 520 meters at 2,4Ghz.
They fit well in head.
Note:
The bag for the goggles will be larger and have a bigger weight than the bag you use for your spark and all the accessories... it is not so portable as spark is...
Buy the OTG cable accessories on Dji store page. Pluging the OTG cable with normal Usb-micro USB cable you will have a kind of microusb-microusb cable, however the communication between spark RC and the goggles will only work if you connect the OTG to de RC an not to the goggles.
