fhagan02
Flight distance : 1854908 ft
Yep thankfully you were able to control!
It's not uncommon for a card to work fine...and then not. The video records a Variable Bit Rate (VBR). So what that means is if you're recording a scene while not moving, hovering in place or moving slowly, the bit rate stays low (20-30Mb/s) as the details in the shot aren't rapidly "changing." When you start moving and flying through a lot moving detail (like trees, leaves, blades of grass etc.) the VBR ramps up (60Mb/s) to be able to capture all that "changing" detail. So in theroy the video you shot while the "card was working fine" could've just been low detail scenes so the card never had to ramp up to a higher bit rate. You just didn't know it. I've had sd cards work just fine and then, with no warning, give an error, become corrupt etc. Have you tried a different card? Process of elimination is where I'd start. (Obviously make sure all your firmware is up to date as DJI released 1.1.9 a couple days ago.)
Hope this helps and keep us posted.
