fansdf1d61d3
Flight distance : 12241 ft
Thanks for the replies. So basically I updated the controller first, with the aircraft switched off. I found that when the controller was connected to the aircraft it gave me the network error. With the aircraft switched off, and the remote controller on, the controller firmware update went through smoothly.
Next, the aircraft had to be done via PC, as using my phone had no luck on both Wifi and 4g. I installed DJI Assistant 2 and tried connecting the mavic 2 pro to it, but it was dropping my wifi connection and looking at the mavic as a network connection (so I lost internet connectivity). I restarted my computer, recharged the drone battery, and I used an ethernet cable from my router to my PC, and this worked, and I was able to connect the aircraft, download the firmware and within 10 mins it was all done. |
