fabien.email
Hi,
their solution is not a " full" solution, because the problem is not the frames bending on the S900, these are the 4 aluminum " legs" supporting the gimbal and the battery + dampers which are oscillating with the landing gears vibrations. Simply because each "leg" is retained by just one screw to the frame, which is not stiff enough, then a carbon tube on each side links 2 legs + Landing gear unit, and landing gear unit is fixed with just one screw also. This is the central carbon tube between the 2 landing gears unit that gives the necessary stiffness if it is glued, or gives a complete wobbly assembly if not .
So their upgraded frame will stiffen the.. frames only, but original ones are stiff enough already, only the landing gears cause troubles and landing gear issue is located on.. landing gears, their anchors, and how they are linked to each other AND to the battery / gimbal support.
Before buying expensive gizmos, just make 30 minutes and glue the central tube between the 2 landing gears unit, it requires just a bit of time and 15usd for the Epoxy resin and sandpaper, and give it a try before making such an expense
BEst regards,
Fabien |
