TJH
Flight distance : 50830 ft
I have two Phantom 4 Pro drones; one being a Plus+ and the other uses a mini Apple tablet. I tend to use the tablet most of the time since the screen is larger. Since there was a minor update for tablet drone the other day, I decided to check for any updates for the Plus+ drone. For some reason now, the controller now continues to beep when turned on. Once calibrated it stops. But when turned on again the beeping's starts again until controller is recalibrated. When calculating, it only takes a couple seconds before is done. Not sure if that correct or not, or if there another phase of this to be completed also. I've never had a problem with the controller, so this is a bit of a surprise.
