MA shaking and drifting
687 10 2018-9-4
hugoleveille
Flight distance : 370174 ft
[size=15.600000381469727px]
Hi
I did a flight yesterday over a very high pedestrian bridge. I tokeoff from a flat surface with 10 satellites away from the bridge to make sure any metal from the bridge( even if it was mainly in wood) would not mess up the compass. I was not requested for compass calibration
After 20 sec in the flight, the drone was pretty much in front of me and noticed that it was shaking like a dropped penny on the ground just before it stops moving. Also, for the first minute, it was drifting alot. You can see in the log at 20 sec in the flight that it is moving without user input.
At first I was thinking of wind but i really doubt it. Then it stabilized itself and was fine for the rest of the flight
Any ideas? Could 10 satellites affect this? I usually start with 10 without any problems
FLIGHT LOGS:
https://bit.ly/2oD7P1k
2018-9-4
hugoleveille
28 sec into the flight is the worst part. Drifting and shaking
2018-9-4
DJI Paladin
Super Moderator
Flight distance : 318 ft
Sorry for all the trouble. If you change an environment, you can calibrate the compass before flight. Or the app will remind you if you need to calibrate the compass. Did you receive an error message on the APP?
2018-9-4
hugoleveille
No, I was not requested for a compass calibration. I was told to not calibrate unless asked by the app. Is this advice legit?
2018-9-4
WayneMHK
Flight distance : 694728 ft
hugoleveille Posted at 2018-9-4 09:44
What FW version are you on?
2018-9-4
hugoleveille
Should I calibrate when moving even is not asked by app?
2018-9-4
hugoleveille
DJI Paladin Posted at 2018-9-4 09:42
2018-9-4
hugoleveille
WayneMHK Posted at 2018-9-4 11:12
The latest .400
2018-9-4
0rcinus
Croatia
Turn vision off, keep it off, see if it ever happens again.
Ever since i disabled it, any stability and drift issues magically stopped and never returned.
And i’m not talking low light either - broad daylight drifts, shakes and whatnot else.
IMO, vision system on MA is more trouble than it’s worth.
2018-9-4
Amjad1983
Flight distance : 310489 ft
United Arab Emirates
I got same issue with drifting  but only happens with smart mode helical shots and few (sensors supposed to be off)
I was sure its not related to wind because it happned at the same moment for each shot
2018-9-4
DJI Paladin
Super Moderator
Hi, here are some scenarios that we suggest calibrating the compass:
When the aircraft moves erratically during flight, i.e. the drone doesn't fly in straight lines. You can go this route: MC Settings--Advanced Settings--Sensor--Compass--calibrate. When the app prompts that the compass needs to be calibrated, the drone’s compass has suffered from interference as the aircraft was turned on in a place where there is magnetic interference. Make sure to fly the aircraft in an open area free of interference.When powering on the drone, ensure that the aircraft is at a standstill. If there is interference or the aircraft is powered on during movement, the compass’s orientation may be altered, and then re-calibration is needed. To ensure the flight stability, the app will prompt you to calibrate the compass when there is a need. Please follow the app and calibrate it. Thank you for your support.
2018-9-5
