fans631a749c
Flight distance : 35154 ft
So what we know so far:
1. With the original Mavic Pro (not Mavic 2) the Goggles connected to the REMOTE and signal was not an issue. Everything was awesome.
2. With Mavic 2, the Goggles are connecting directly to the Aircraft, not via the remote. Due to some kind of issue with the setup, the range is severely limited and I personally lose connection at less than 200m (<600ft)
3. Attaching the 5.8Ghz pagoda antenna to the goggles, which is meant for analog racing drones, helps a little bit. But we are talking about going from terrible to horrible. It's NOT worth talking about this any further. Please stop suggesting this, it's just a distraction.
4. Turning the goggles off mid-flight, restores your connection because now your remote is talking directly to the aircraft, instead of your goggles.
5. It has been suggested that connecting the USB cable from the goggles to the USB port on the remote, may help. You need to disconnect your phone and the cable your phone uses from the remote. You must remove the cable from the port on the side of the remote, to be clear, in order for the bottom USB port to activate. Anyone trying this pls post your results.
6. It has been suggested that forcing your goggles into 2.4Ghz mode, and also forcing the aircraft to 2.4Ghz mode will increase your range substantially. Anyone trying this pls post your results.
Thanks all. |
