2 seconds RAW interval
sys101
Israel
  • does anyone know if 2 seconds interval RAW shooting, is something that will be available in future updates of the Phantom 4 advanced?
2018-9-20
KEJ
Hi
I see we have it down to 5 seconds, but I am assuming for some sort of time lapse 2 seconds is more desirable ?
I would have thought not that difficult to add providing the willingness and number of users are there.
May I ask why you are requesting it, as if it is for the above its not something I have played with yet and I am always interested in trying new things.
Cheers
2018-9-22
Landbo
Flight distance : 502792 ft
Denmark
I do not think that will happen, because it takes longer time to write a RAW image to the SD card than two seconds.  ;-)
Regards Leif.
2018-9-22
KEJ
Landbo Posted at 2018-9-22 05:38
Regards Leif.
I think I understand what you mean and whilst I take HDR/Bracketed shots 5 at a time, I assume these get cached and can therefore be written to the SD card before the next similar shot is taken.
Whereas if you are saying that a continuous process of a shot every 2 seconds may potentially cause an issue with processing, cache overflow and write times.
However, 2 seconds may be enough time, it would be interesting to hear DJI official technical response as if it can cope admittedly with high 4k 60fps processing, although I appreciate the amount of data per frame is less.
Expert knowledge required(unless of course you have already provided that), good point.
2018-9-22
sys101
Israel
KEJ Posted at 2018-9-22 02:07
Hi
It would be nice to have the opportunity to shoot 2 seconds RAW interval, because the flight time is a little bit more then 20 minutes. when shooting day to night time lapse, it will make a Hugh difference. It is a must have feature.
2018-9-22
KEJ
sys101 Posted at 2018-9-22 09:28
Thanks for the info
2018-9-22
