mtnmaddman
I have 2 Samsung tab s's, That I use I have tested many units as I am the developer- manufacturer of the nebula alien sunglasses wireless fpv system, If you have a Samsung product and downloaded the lollipop upgrade you are really screwed, Your WIFi direct will not work at all while flowing video via USB port, If you have my glasses and are connecting wirelessly do not download lollipop The app will run about ten minutes, lagging all the way until it finally will stall completely and crash the pilot app. (without my glasses hooked up). I sent one tab s back to samsung they reset the tab to 4.4.2 I have had 4 full flights since with only slight skypeenous. (new word) I got the tab back with no building delay through the flight , the video flow is slightly skypee, The samsung tab s is a reasonably fast top of the line tab and if DJI cant make the app function correctly on it we are in trouble. I have an Nvidia Shield the video flows perfectly and my glasses will plug direct hdmi perfect video flow on tab and glasses, the compass though sucks and I will not use the Nvidia It has magnets in it, I do not want it near my sensitive equipment. I am waiting for a fix from DJI. or there hdmi upgrade for the phantom 3 my glasses plug directly in to the remote (tested on Inspire) video flow at least through the glasses solved.
Now the delay, crash and overheating is due to : (my software crash reports indicate) I believe that Dji is using a form of Java to flow the video the Java is looping this is what my equipment is saying this would overheat the processor constantly resseting causing the lag and eventually overheating the processor , look there Dji. Mtnmaddamn |
