Kyokushin
Flight distance : 296381 ft
Poland
I have no lag increase in flying. I have huge CPU overload caused by something connected with GPS in drone.
Turn off Google Play Services and problemwith overload is gone, but then maps do not work (but positioning still work, and even i have 12 GPS there is no CPU overload, no lag and stuttering)
Lag and stuttering is starting when i get CPU load at beyond 85%. When i disable google play services i have 55% CPU load, WITH satellites positioning, but without map.
And the now will be the most curious part:
- Run DJI app and buffer map (load at 85%), stuttering, lags
- in background disable Google Play Services
- return to DJI (from background, do not close/open)
- and now you have lag and stuttering free piloting, with buffered map and fully GPS positioning, and at load 55% CPU.
And this huge CPU load may in some cases be a cause for thermal problem and CPU throttling down (not mine, but some others).
If you fix huge CPU load connected with GPS, you will solve the thermal problem too, maybe even on both platform.
We all posting here our speculation, we made tests, we trying to help DJI and devel team to find a solution or give some information.
Temperatures in my country are about 75F (23C)
