Lonesome Crow
Flight distance : 406076 ft
Steps I do are simple to try. The MP is turned on first. Once all the beeping is done, I then power up the Android device, my being a Samsung 6. Once the Samsung is on, I connect it to the controller, using the USB port underneath in the the center, to the micro USB on the Samsung. Then power up the controller. You should see the phone screen ask about something referring to the USB connection, like needs to access a file. (I get different questions from my Samsung than I do my tablet). But getting the prompt means you have the right cable, so answer yes. My controller will start the DJI Go 4 app from there on it's own. Then you should be connected, and see what your camera is looking at. I don't use those little short DJI cables to connect my Samsung to the controller, but be sure to look for the big USB connection on the underside of the controller. Highly recommend using that one. Let us know how that works. |
