Ok to use portable 12volt car jumper to charge?
706 11 2018-9-29
offtheback
Flight distance : 13086942 ft
Anyone have experience using a portable 12 volt jump starter battery to recharge drone battery in the field?Would use Mavic 12 volt car charger hooked to the portable starter.
2018-9-29
rwynant V1
Flight distance : 4842277 ft
As long as it's the Mavic 2 Car Power Supply,  and N O T the Mavic 1 Car Power Supply!!
2 Different voltage outputs
Randy
2018-9-29
offtheback
rwynant V1 Posted at 2018-9-29 16:07
Thanks.Tried one tonight and the Mavic battery only charged intermittently.Is that because the 12 volt jump battery voltage dropped below the cutoff voltage?
2018-9-29
rwynant V1
You would need to meter the Jump Battery voltage under the load .......
You need to answer this question:
Are you using the Mavic 2 battery power supply,  or the Mavic Pro battery power supply....???
Thx
Randy
2018-9-29
offtheback
rwynant V1 Posted at 2018-9-29 19:15
Sorry-it's the Mavic 2
2018-9-29
rwynant V1
Do you have a volt meter?          BTW "intermittent" is NO Bueno
Set it to 20 VDC
Check the output voltage of the power supply connected to your Jump Battery....   = ?
Randy
2018-9-29
offtheback
rwynant V1 Posted at 2018-9-29 19:24
Set it to 20 VDC
Don't have a voltmeter but the no bueno doesn't sound good.I have an AC inverter.Maybe that will work better?
2018-9-29
rwynant V1
I use a 400 watt Inverter for my mobile charging, but use a 12 volt Deep Cylce Marine battery for the power supply.  About $100 for the battery.   Can plug in the stock power supply to charge 1 battery, and use the Car charger in the Acc outlet to charge a 2nd battery while driving.
Randy
2018-9-29
offtheback
rwynant V1 Posted at 2018-9-29 19:34
Call me.........it's ok      619-977-9162
Thanks.Sounds good.
2018-9-29
DJI Wanda
Hi. Thank you for reaching DJI Forum. Sorry, but we do not recommend to use third-party accessories. We highly recommend using the car charger that was included in the fly more kit. The M2 battery is a LiPo 4S battery, so we can't use 12V.
2018-9-30
offtheback
DJI Wanda Posted at 2018-9-30 05:31
[view_image]
So is it ok to use the Mavic 2 car charger plugged into the car's lighter socket and charge the Mavic battery with the car engine off?
2018-9-30
DJI Wanda
offtheback Posted at 2018-9-30 05:51
It actually depends on what type of car you have and also if the car is on rest or not. You may charge the battery when the engine is turned off, just put it on the ignition state but it is not suggested as to the battery of your car will quickly be discharged.
2018-9-30
