JERKY VIDEO
12Next >
3798 51 2018-10-2
Cool0102
Flight distance : 550548 ft
I'm still very impressed by the quality of Mavic 2 Zoom videos I see on Youtube.
Unfortunately, my videos are jerky even in tripod mode. I use a 32 go Sandisk Extreme Pro U3 V30
Is there a problem on my Mavic 2 Zoom ?
Example here (4k, 60fps):
2018-10-2
Cool0102
Here, a vidéo 4k 30fps
2018-10-3
DennisMurry08
Flight distance : 5948264 ft
Are you uploading to YouTube straight off the SD card?
2018-10-3
Cool0102
No I don't, I use Premiere Pro (same source and ouput).
I did a camera reset and have posted here the result  (4k,30fps, Mode P, no wind):
2018-10-3
jwt-873
Flight distance : 6754350 ft
Youtube sometimes mangles video..  Especially if you don't follow their recommendations   https://support.google.com/youtube/answer/1722171?hl=en
Can you post a short unedited  video directly from your SD card to one of the online storage sites, (like DropBox). ?   That would make it easier to tell whether or not there's a problem with your recorded video.
2018-10-3
Cool0102
OK, this link will be available soon (transferring): https://www.dropbox.com/s/e4n1fqbhk0jpbbz/DJI_0086.mp4?dl=0
2018-10-3
jwt-873
I downloaded the file rather than view it on the Dropbox viewing screen.   (That Dropbox streaming screen can also have issues).
This is odd..     I have two computers.  Both have speedy  i7 processors.   One runs Linux and the other Windows 10.     The video has a slight stutter on my Linux computer using the VLC video viewer.  It also has a slight stutter when using VLC on my Windows computer.    But -- when viewed on the Windows computer, using the native Windows app (they call it Films & TV), it's as smooth as glass.
I put the file on a USB 2 thumb drive and plugged it into my 4K Samsung TV.  It played smoothly there as well.
So..  The video seems fine.   Either the video player you're using, or your video graphics card, or the speed of your computer is causing the jerky frames.   Perhaps someone else can provide more insight on this...
Edit..   Using Linux all three of the videos you posted have some jitter to the frames.   I fired up a browser on my Windows computer.  The first two videos show frame jitter, but third one (in post #4) is pretty smooth.
2018-10-3
Cool0102
Many thanks for your messsage and test.
I've sent 2 other videos to the DJI Support showing that even when registering the video on the internal memory of the Mavic the problem persists.
The DJI support just answered, some minutes ago: "Unfortunately, we have not encountered this type of problem so far and need to get back to the development team to find out about the possible solutions."
2018-10-4
DennisMurry08
Cool0102 Posted at 2018-10-4 07:25
Try an experiment...take a copy of your original video and render it at 1080...then try 2.7 if your software allows. See what you get with that....another thought is use 4k on Vimeo...seems to handle 4k better than YouTube.
2018-10-4
Cool0102
DennisMurry08 Posted at 2018-10-4 07:39
I've tried to render the 4k original video at 1080 with Premiere). No change:
https://www.dropbox.com/s/tjp1j4m4beb2ji9/DJI_0014_1.mp4?dl=0
2018-10-4
theothernt
Flight distance : 436171 ft
What are the camera settings you use - ISO, Shutter speed, etc ?
2018-10-4
Cool0102
For this video: Auto, 3840x2160, 25fps, PAL, D-Cinelike, ND16.
I've tried different speed, fps, shuter, ISO... and the result is the same (however less visible in 4K 60fps).
2018-10-4
theothernt
Cool0102 Posted at 2018-10-4 08:47
If possible, can you try...
4K, 30fps, 1/60, ISO 100 - panning left to right and up and down, slowly if possible?
also, are you sure about 4k/60fps - I didn't know that was an option on the Mavic 2 range?
2018-10-5
Cool0102
theothernt Posted at 2018-10-5 09:19
I'm sorry.. It was 2.7k 60fps. You're right there is no 4k 60fps on the Mavic 2! DJI wants to continue selling the Phantom 4 pro!
2018-10-5
theothernt
Cool0102 Posted at 2018-10-5 09:40
No probs
And if you're able to make another video, post it here. Assuming there's a fault with the drone, the up/down motion would test the gimble, and left/right the drone itself.
(about the camera settings, just make sure everything is on manual including white balance)
2018-10-5
Cool0102
New test: 4K, 30fps, 1/60, ISO 100 - panning  up and down and right to left. Please, don't consider the aperture and focus! I dind't take off the ND16...
https://www.dropbox.com/s/6w234c36lf25u1w/essai%206.mp4?dl=0
2018-10-5
Cool0102
I've tested a dronie 4k, 30fpd, iso 100, sligthly cloudy, filter ND4...
https://www.dropbox.com/s/90ousaoy6ehpmov/test%20dronie.mp4?dl=0
2018-10-6
WRHershey
Flight distance : 116043 ft
Are you using the video cached on your display device or the video captured directly on the SD card in the Mavic? The video cached on my display device often looks jerky, but the video actually captured on the drone is fine.
2018-10-6
Cool0102
WRHershey Posted at 2018-10-6 23:39
These videos are from the SD Card or the internal memory.
2018-10-7
AlansDronePics
Flight distance : 814751 ft
Guernsey
There was a Vlc version a while ago that didn't play my mp 4k 30fps smoothly but the win 10 app worked fine, as you said. Another reason that can be unrelated to the players but concerns the encoding is if the computer is busy. If on Windows you press control, alt, delete simultaneously to load the app that shows processor, network, graphics and memory load, you may discover something running that shouldn't.
2018-10-7
Cool0102
I don't think that the reason is because of the computer. The following image shows activity of processor, GPU and memory during the encoding:
2018-10-7
infusopharm
Flight distance : 158980 ft
Had the same problem with my new Mavic 2 Pro. Ended up returning the Mavic costing me $50 in return shipping and insurance. Spending time getting my DJI Cares refund and loss of registration fee along with now a higher retail price. Looks like yours will be heading back also.
2018-10-7
Cool0102
infusopharm Posted at 2018-10-7 07:27
Interested to learn that I'm not the only one to experience this problem! I still hope that DJI will find a solution as I was said that they will ask the development team...
2018-10-7
Mic4
Hello,
I've got the same probleme.
When I film my travel with my mavic 2 zoom, video's jerky or accelerate
I can't find why
Have you got a solution aboyt DJI
Thank you
2019-4-21
NightThunder
Flight distance : 106020 ft
Same problem for me only much, much worse. Doesn't matter what picture size, frame rate, AFC, AF, MF, internal / SD storage and all of the rest of the alphabit soup. The stuttering is unacceptable and video is garbage. Looks like M2P is going into the shop too as soon as I get in touch with support tomorrow.
BTW: Also did a full recalibration including calibrating the sensors (which is a PITA), no joy.
2019-4-21
NightThunder
Forgot to mention that I was working with support last week and sent them a video. They verified that the video was indeed shakey. Told me to recalibrate which I did with no change in the problem. I really believe I have a defective M2P.
2019-4-21
NightThunder
Here is a link to my jerky video on a M2P in case anyone cares.
https://www.dropbox.com/s/i49xy2ocjub9v8l/DJI_0129.MP4?dl=0
2019-4-21
NightThunder
Jerky video
2019-4-21
AntDX316
Flight distance : 3394731 ft
Upload the file from the drone to google and give me the shareable link.  I will see if my rendering makes it not jerky.
2019-4-21
AntDX316
You don't need 4k.  Just Opticalflow in Resolve.
2019-4-21
NightThunder
AntDX316 Posted at 4-21 14:57
Thanks for the help. Posted the link in a previous message but didn't do it as a link. Tried to correct it but the fracking two minute time had expired and it would not let me edit. New to this forum. So here is my second attempt to add a link:
Here is the link:
This
2019-4-21
NightThunder
2019-4-21
NightThunder
NightThunder Posted at 4-21 15:26
Sucks that adding a link does not work (at least for me). Use above to paste into browser.
2019-4-21
AntDX316
yeah, It's jerky lol even with Opticalflow and I tried stabilization to max after but it does nothing.  Are your props chipped?  Imbalanced props can cause things like this to happen.
2019-4-21
NightThunder
AntDX316 Posted at 4-21 15:37
https://www.youtube.com/watch?v=CIk4oKgm1-s
I am using low noise props from DJI. I have examined my props carefully and see no problems with them. I suppose I can try the original props... What a PITA. Thanks for looking at that. Gotta learn how to add a proper link.
I should addd i tried "hand flying". Same problem.
2019-4-21
AntDX316
NightThunder Posted at 4-21 15:58
yeah, the props that came w/ the drone I assume would make it stable
make a video outside now to see?
2019-4-21
NightThunder
AntDX316 Posted at 4-21 16:00
Will do. Hand flying I added to previous message is from memory only. Not very trust worthy at my age. Thanks. I'll let you know.
2019-4-21
AntDX316
NightThunder Posted at 4-21 16:02
yeah, someone posted somewhere that it got sent in for repairs and it got fixed
2019-4-21
NightThunder
AntDX316 Posted at 4-21 16:29
Yeah, that's what I expected. New porpos made no differnce. Gonna do some handflying, leave on the internal memory then send it  in. Thank you SOOOO much. I suggest that the op might want to do the same. Wasting way to many hours on this.
BTW: I downgraded the FW version to 2 versions back. Same problem.
2019-4-21
AntDX316
NightThunder Posted at 4-21 16:40
yeah, what is handflying?  You are sending it to DJI?
2019-4-21
12Next >
