New Phantom 4 Pro V2.0 Firmware Released (10/08/2018)
12
14843 59 2018-10-8
Sergio069
Flight distance : 748 ft
Belgium
Hello,
Me again,
More over, my remote controller is well recognised by windows 10 but "ignored" by assistant 2.0.2 for phantom since last firmware.
"Once the firmware is updated, it cannot revert to a previous version. Restart the aircraft and remote controller once the update is complete."
WHY?
Thanks
Serge
All this seems to be a real mess!
Super regards.
Serge
2018-10-14
Spirytus
Flight distance : 126864 ft
n55w132 Posted at 2018-10-8 23:45
Thank-you, I tried that as well. I am wondering if it is an occusync 2.0 issue?
On another possibility I do have standard goggles and I know they only work on 2.4ghz and force the controller into 2.4ghz only. However I am not using them. But since they have been linked, even though not turned on I am wondering if it has locked my controller into 2.4ghz only.
The controller is locked in 2.4 GHz after you link your standard goggles (even when not using them).
You have to re-link your controller to re-enable dual band mode, however, doing so, your goggles will no longer work wirelessly (until you re-link them again - locking you back into 2.4GHz only).
If you wan your standard goggles to work in dual bands then don't link them wirelessly to the phantom, instead use the USB cable connected to the RC. This is a PITA though, if you've ever used the cable with goggles you'll know.
2018-10-14
Cliff_622
Flight distance : 512005 ft
Flew the new firmware. STILL has bad yaw drift. Even after vertical gimblal calibrate, my P4P+v2.0 will sway left and right during orbits and will not fly straight. This mornings winds were very very light too.
I don't know what is going on with the resolution of this compass and how it interacts with the yaw on this drone. I'm really getting tired of this and I want DJI to address this in some kind of announcement. I love the P4P image quality. It really IS fantastic but what good is it when orbit shots has strong yaw corrections in it that ruin your shot? I'm literally flying my Mavic Air, Mavic-2 Zoom and Mavic-2 Pro with 100% PERFECT success. My TWO Phantom 4 Pro+ V2.0's literally cant even do what ANY of the Mavics can do in terms of yaw stability.
2018-10-14
katho3d
Flight distance : 32989 ft
Austria
Cliff_622 Posted at 2018-10-14 09:27
I don't know what is going on with the resolution of this compass and how it interacts with the yaw on this drone. I'm really getting tired of this and I want DJI to address this in some kind of announcement. I love the P4P image quality. It really IS fantastic but what good is it when even orbit shot has strong yaw corrections in it that ruin your shot? I'm literally flying my Mavic Air, Mavic-2 Zoom and Mavic-2 Pro with 100% PERFECT success. My TWO Phantom 4 Pro+ V2.0's literally cant even do what ANY of the Mavics can do in terms of yaw stability.
Same here, my P4P+v2.0 has also a very noticeable yaw drift. Even if I don´t touch the sticks the drone pans left or right.
2018-10-15
jacksond
Flight distance : 50991 ft
Updated. FML. anyone got an old rc firmware copy? dropbox it here please
2018-10-15
Charliechan12
Flight distance : 709 ft
I looked also to see if anyone posted old copy.  Funny on some posts I see an administrator posting replies.  This must be one site they can’t log into.
2018-10-15
fans36cc2f83
Flight distance : 2569364 ft
Hungary
Sergio069 Posted at 2018-10-13 11:57
Hello,
Just upgrade today my P4P+ to latest firmware?
+1
I use custom stick mode. Changing stick mode seems not to be saved. The remote always go back to mode 2.
This is a very big BUG!!! ((
This is so bad... Please fix it DJI .....
2018-10-16
Mavic_Timo
Flight distance : 773025 ft
Kosovo
Guys because a lot of you addressed this yaw drifting issue, I went out for a flight yesterday and noticed I got it, too
2018-10-19
Ali Hilmi
Indonesia
Mohon info DJI p4 v2 battei error
2018-10-20
Brett Walsh
Flight distance : 6518511 ft
Found an issue.
I fly on Mode 1.
After these updates it continuously defaults back to Mode2 after every restart.
2018-10-20
yuft gtdr
Egypt
I can second and confirm the issue with the right camera settings dial being too sensitive and jumping multiple values between each graduation
2018-10-23
JohnnyGT
Flight distance : 42733 ft
New Zealand
DJI SUPPORT·WEDNESDAY, OCTOBER 24, 2018
Overview
Date: 2018.10.24
Aircraft Firmware: v01.00.22.00
Phantom 4 Pro V2.0 Remote Controller Firmware: v01.00.22.00
Phantom 4 Pro+ V2.0 Remote Controller Firmware: v01.00.01.00
DJI GO 4 App iOS: v4.3.3
DJI GO 4 App Android: v4.3.2
What’s New?
Optimized the sensitivity of the remote controller's right stick when adjusting camera parameters.
Fixed an issue where after restarting, the remote controller automatically reset to Mode 2 even if the remote controller was set in a different mode.
Notes
If the firmware update fails, restart the aircraft, remote controller, and app, and try updating again.
2018-10-23
lliu0130
Flight distance : 203655 ft
Taiwan
Cliff_622 Posted at 10-14 09:27
Hi Cliff,
     I faced same issue like you until I use P4Pv1 propellers. Yes, I used non low noise propellers and P4P v2 will not drift on hover. Thanks GOD!
Louis
2018-12-25
lliu0130
Taiwan
katho3d Posted at 10-15 03:44
     I faced same issue like you until I use P4Pv1 propellers. Yes, I used non low noise propellers and P4P v2 will not drift on hover. Thanks god!
Louis
2018-12-25
Kuruppu
Flight distance : 501877 ft
Sri Lanka
Pro + v2 Remote Not  Detect please help me
2019-4-13
Kuruppu
Sri Lanka
2019-4-13
Kuruppu
Sri Lanka
Pro + v2 Remote Not  Detect for DJI Assistant Software please help me
2019-4-13
Kuruppu
Sri Lanka
2019-4-13
Kuruppu
Sri Lanka
2019-4-13
Kuruppu
Sri Lanka
2019-4-13
12
