DeuceDriv3r
Flight distance : 4698533 ft
KlooGee Posted at 2018-10-17 19:51
I disagree that it’s loss of GPS signal that normally causes the Spark to jump into ATTI mode. I’ve investigated the logs of a large number of incidents that users have posted on this forum and they are almost always compass/yaw issues that cause it to go into ATTI mode. There are some notable exceptions to that where one user was flying in a canyon and a few others flying into covered areas such as caves, culverts, under bridges,etc. However, the vast majority of the incidents I’ve investigated were compass/yaw errors.
start your motors on the ground.. don't take off but be connected to the App
hold your hand over the spark for a couple seconds... it will loose sats almost immediately and jump to atti in less than 3 seconds...
you get ANYWHERE where GPS signal drops, under trees, near interference like power lines, flying though a microwave repeater between 2 towers (most are at or below 400'), or depending on the GPS rejection algo in the GPS chip, in places where the GPS signal can be bouncing off building etc thats called multipathing and the GPS will drop any satellite that it doesnt 'trust' and won't be allowed back in the solution
some of that same interference also spins the compass.. but regardless of WHY it goes into ATTI... if you have the sticks in full ... the AIRCRAFT is already going full tilt BEFORE you get the WARNING.. and if its at the edge of your VLOS .. you will have a very difficult time in a hurry... if you were close to an object.. it may be too late before you even have a chance to get off the sticks it will jump into full tilt and leap dozens of meters before it tells you its doing so...
... atti mode.. BOOM
