hallmark007
Flight distance : 9827923 ft
kovat53 Posted at 11-8 09:38
Hi,
perhaps you are right. In my case I have never had yaw and drift problem before .400 and .500, never, but AFTER yes.
Today I tried the suggested Fake GPS (really I don't like this kind of behavior) to try stronger wifi communication. Some of my video recording were smooth and (except my lumpish control) perfect. Then I changed my place, and again came this quick turning effect (with all clear sticks). I switched back to CE mode, suddenly came a "strong aircraft interference" pop up, so I switched back to FCC. Pop up message didn't come, but sudden uncontrolled turning yes. Don't know, but it is strange. In my opinion if it would be HW problem, then it must have happened always, not occasionally. Someone (I think hallmark007) suggested to have repaired MA, but for what. Before .400 and .500 my MA had never problem, and now despite of reinstalling every possible software elements, FW, DJI Go 4, I use dedicated phone with plenty of resources from the compatibility list. SOMETIMES comes this drifting (and yaw) problem, AND NOT ALWAYS. I came to the result, MA isn't the most successful product of DJI. The skills are very good, but the operating is unsure at least in my case. What to do? Flying and being scared , and editing, that's the probably one solution.
My point about sending in , was very simple, if your drone has a problem and is not working as it should, then you have a warranty you can use to get it fixed, the vast majority of MavAir are working fine so you should have one that works just like the rest.
You also have the option to wait for new FW to fix your problem, but problem with that is, how long are you going to have to wait and what is to happen if your warranty runs out before there is a new FW and that FW doesn’t fix your problem then your screwed, but if you perceive that your problem is not causing issues then wait if that’s what you think is best.
There seems to be a notion that when you send back, dji will send you back some piece of rubbish, yet the proof of that around here is plenty have got back brand new MavAir and refurbished on the whole have been accepted by others as been a good deal. But there will always be those around here trying to create hysteria and tell you that you are going to get some piece of rubbish, somehow trying to make users think they will receive substandard product in return, which is simply not true and I for one can tell you or anyone else that this is far from the truth. |
