Mavic 2 Gimbal issue in moderate wind
12
7133 46 2018-10-25
dronie1965
Flight distance : 24897940 ft
Roman939 Posted at 3-9 01:36
We must try!!! If it helps, it will be a miracle!!!
Let me know
2019-3-9
Roman939
Flight distance : 369974 ft
Russia
it still doesn't work!!!!!!!!!!!!!!!!!!!
2019-3-9
Roman939
Russia
Мы должны попробовать!!! Если это поможет, это будет чудо!!! это все еще не работает!!!!!!!!!!!!!!!!!!!
2019-3-9
Roman939
Russia
2019-3-9
losga77
Flight distance : 11270 ft
Hi!
i have the same problem!
few days aggo i noticed that when my mavic2 is going backward, even if the braking is not strong, the gimbal drops down few degrees (from zero to -5 or -9). If i put it at zero, the next time i'm going bakward it will happen the same........
Also when i tilt the gimbal few degrees above horizon, as i start to go forward, the gimbal drops down
i tried to calibrate gimbal and IMU and refresh firmware, but did not solve.
Lorenzo
2019-3-29
Renames
Flight distance : 4232851 ft
Ceta is the answe
2019-3-29
losga77
what is CETA???
2019-3-31
12
