Sparkz71
Flight distance : 24259 ft
S.J Posted at 11-1 22:24
take the SPARK outside and use the RC to lift the drone minimum 60 meters high. Check on your mobile if GPS is locked. Now try to use the joysticks on the RC to move forward. It should work. It may take 1 to 2 minutes for the drone to lock and respond to your RC .
wtf? Bad advice!!! Lock the GPS from ground! Only 7 m H needed for the home point to be visually recorded. By the time you get to 60 m, in atti mode, after 1 - 2 minutes anything could happen in the wind!
I do NOT recommend S.J. 's advice - that is asking for trouble.
Wait for a GPS fix before take-off, check the KP index etc. Otherwise, fly on a better day.
